Forums >> Revit Structure >> Tips & Tricks >> Pier caps in Grade beams
Mon, Aug 15, 2011 at 2:41:41 PM | Pier caps in Grade beams
JBarron222
i have foundation walls (or grade beams) and I have pier caps that are integrated into the grade beam (or monolithic).  I am trying to get the pier cap (whihc I used a column family for) to join and clean up with the grade beam.
It works fine in one project, but not in another with the same situation...  I have matched the view range, from the project it works on to the one that I am having troulbe with...nothing
I have verified top and bottom constraints...they match
Same material....yes
can anyone tell me why it works fine on one and not on the other?
Tue, Aug 16, 2011 at 11:31:41 AM | Pier caps in Grade beams
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
did you join them together?
Mon, Aug 29, 2011 at 2:01:13 PM | Pier caps in Grade beams
kbeegles
Is it possible that they are modeled as structural columns in one project and architectural columns in another?  I read somewhere that this can make a difference in how they clean-up with walls.
The Leffler Group
concrete grade bms / pile caps
Thu, Nov 13, 2008 at 2:34:26 PM
Ground beams not joing to pile caps (but usually work fine)
Thu, Feb 18, 2010 at 6:27:45 AM
Pile caps, Beams, and columns not visible in 3d
Sun, Jun 8, 2008 at 6:40:02 AM
grade beams
Tue, Feb 23, 2010 at 2:40:26 PM
Pier Shading
Tue, Mar 19, 2019 at 1:42:11 PM
Page generation time: 0.0673
