Forums >> Revit Building >> Technical Support >> batch pdf's
Mon, Aug 15, 2011 at 12:49:28 PM | batch pdf's
bucksy99
Is there a (better) way to create pdf's than selecting them one-by-one?
I am using cute pdf and can create one sheet ok. When I select multiple sheets it asks me in a pop-up window for the file name, then the next window pops up before I can name the first one, etc.
I know cute pdf is not made for revit. Is there anything out there besides Acrobat pro that works?
Thanks a lot.
Mon, Aug 15, 2011 at 1:12:40 PM | batch pdf's
We use cute and it works fine.
With cute, you can combine PDF's in one file, otherwise the pop-up's do happen but they will be one behind the other.
Mr Spot has a manager program available:  http://www.cadway.com.au/
Tue, Aug 16, 2011 at 11:47:39 AM | batch pdf's
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I use PDFCreator, also can make other file types, combines, and free.
Tue, Aug 16, 2011 at 12:11:36 PM | batch pdf's
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You should be able to preset the output location and disable the preview option.
We use Acrobat Pro and once you specify the output location in the Adobe driver and disable the preview we are able to print the PDF file(s) however we want and just let it run in the background...never get prompted for a file save location (name) or see a preview.
We also do this in Adobe Standard.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Aug 18, 2011 at 5:42:21 PM | batch pdf's
bucksy99
thanks everybody!
I will give it a try.
Fri, Aug 19, 2011 at 2:07:51 PM | batch pdf's
bucksy99
mpsteve, I tried out PDF creator and it creates the batch perfectly. Is there a way to have it automatically name the sheets the same way they are named in Revit instead of the numbers?
Thanks.
Fri, Aug 19, 2011 at 5:11:24 PM | batch pdf's
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
when you save the file you have the opportunity to name the file
Sun, Aug 21, 2011 at 2:00:55 PM | batch pdf's
bucksy99
thanks, but can PDF Creator automatically name the sheets based on how they are named in the revit file?
Autocad imports PDF's. Is there anyway Revit does that?
Mon, Feb 1, 2010 at 5:06:18 PM
How to print different sheet formats in PDF?
Mon, Jun 5, 2023 at 2:07:16 PM
Batch plotting folder location
Thu, Jan 21, 2016 at 1:40:58 PM
Printing PDF's
Tue, Oct 26, 2010 at 11:21:57 AM
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:07 PM
Page generation time: 1.0061
