17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Ceilings not showing
2 Posts No Rating |
Hi I have ceilings throughout my plan. They show in section, in 3d and in elevation. However they don't show in my RCP...it is not allowing me to place lights on the RCP except in one room. I sketched the ceiling in each room. Ceilings are on under VG. When I highlight the area and do filter they do not appear. However if I look at my 3d view they are there...PLEASE HELP...I can't figure it out!! Thanks!!
How did you do your reflected ceiling plans? They are not a floor plan.
Also check VG and phases.
2 Posts No Rating |
Thanks...the ceilings were created on the Ceiling Plan option...and they are showing in VG..still can't figure it out
what height do you have your ceiling at? If your cut plane is not set up correctly in that ceiling plan you will not see it.
1st - What is ceiling height?
2nd- Go to ceiling plan and tell me what you have for a value in all the boxes under your View range tab. Cick on the ceiling plan then type in VP and scroll down till you see view range.
With this information we should hopefully be able to resolve the problem. Good luck.
Ceiling diffusers not showing up in ceilings when combined with architecturals |
Wed, Sep 2, 2009 at 5:20:10 PM
Model In Place Ceilings Not Scheduling?? |
Wed, Jan 15, 2014 at 10:55:35 AM
Ceilings Not Showing In Elevation/Section |
Thu, Oct 1, 2015 at 7:31:33 AM
Complex ceilings |
Thu, Oct 8, 2015 at 1:02:54 PM
Existing Phase / Ceilings solid gray |
Mon, Oct 15, 2012 at 12:40:18 PM
