Forums >> Revit Building >> Technical Support >> Imported family is exploded in project
Fri, Aug 12, 2011 at 3:43:02 AM | Imported family is exploded in project
shenlunglinnk
3 Stars: 2 Votes
Hi
I made a family composed with 3 elements, then imported it into my project.
However, one of the elements was not shown in correct position in the project, please see the attached images.
It happens quite often that families are "exploded" when I imported them in to projects
Dose anyone knows how to fix it?
Thank you very much
Fri, Aug 12, 2011 at 6:46:22 AM | Imported family is exploded in project
Families are not exploded ever and they are inserted - not imported....so what are you really saying?
BTW - You images have no meaning to us - we have no way of knowing what the problem is.
Fri, Aug 12, 2011 at 7:07:20 AM | Imported family is exploded in project
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hello,
I think the part you are missing in your family creation is constraints...  Geometry that has to interact with other elements generally has to be constrained.  This typically refers to Hosted families such as wall based, floor based families etc.  If you model your geometry in a particular position it is based on the wall or floor being a certain thickness.  The wall you host it to in the project may be a different thickness thus the geometry gets pushed about if its not constrained properly.
Lack of constraints will also cause you these "exploded" like behaviour you described when you are attempting to make things parametric...
Regards,
Chris.
Fri, Aug 12, 2011 at 7:31:02 AM | Imported family is exploded in project
shenlunglinnk
3 Stars: 2 Votes
Hi Chris
That's the right answer, everything works now :-)
Thank you very much for your help.
HELP! importing 3D objects cant be exploded
Fri, Nov 10, 2006 at 10:48:19 AM
exploded views and sheet feature in revit family editor
Mon, Mar 24, 2014 at 10:55:30 AM
Toposurface Using Imported Instance
Thu, Oct 2, 2008 at 1:14:01 PM
dxf 3D imported blocks
Sat, Dec 6, 2003 at 11:06:06 PM
Cannot find the model or family I just imported!
Sun, May 21, 2017 at 7:34:50 AM
13
Page generation time: 1.4626
