Forums >> Revit Structure >> Technical Support >> Two issues with the Revit Structure 2011
Thu, Aug 11, 2011 at 1:11:47 PM | Two issues with the Revit Structure 2011
leetkinda
Hi,
i have spent hours trying to resolve these issues, i would be glad if somebody could give me a hint. I'll try to give you as much information as possible.
Here is the file - http://dl.dropbox.com/u/22273768/errors.rvt
1) Running a consistency checks will churn out 42 errors,
41 of them are these
"Distance between Analytical and Physical Models of Structural Element is beyond tolerance of 150.0"
All of them relates to slanted columns only.
I understand the difference between analytical and physical model, but i really dont get this error message occurance.
I tried to play around with level heights, Construction parameters (base/top cut style, base/top extensions..) and i tried to change the element type. None of it worked.
2) I carefully set the grids, levels and modeled the construction. What im trying to achieve is scalable project, changing the grids and levels would allow me to stretch the construction.
Now the first time, there wasnt a single problem moving with levels and grids, the construction scaled as i wanted.
So I set to do a different version of the construction and saved as - the original project. Before I made any changes whatsoever, i said to myself "lets try if it is still scalable", well and it wasnt. After i tried to move the grids (Al, Bl, Cl, Dl - just horizontally and vertiaclly few hundred millimeters to be specific) - bunch of "Can't keep elements joined" errors and it varied several times in terms of number of elements that cannot be joined anymore. It seems like the variety of elements that creates this errors changes every time i open the file.
During the modelling I was extremely carefull to place the beams, columns and slanted columns only on grids. I hid all the other elements before I started modelling other elements..
So the question is what went wrong, how to make it right and why the hack the error messages varies?
BTW moving with the height of levels worked every time, it is just the grids and the slanted columns..
Thanks for any replies.
Thu, Aug 11, 2011 at 1:50:53 PM | Two issues with the Revit Structure 2011
leetkinda
Also, would you use slanted columns or brace to model the construction? What would be the difference? Thanks
Inventor to Revit Structure 2010 or 2011
Fri, Dec 10, 2010 at 5:45:29 AM
Revit Architecture / Revit Structure Coordination Issues
Fri, May 7, 2010 at 10:19:04 AM
Revit 2011 upgrade
Fri, Jul 2, 2010 at 7:15:32 AM
Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Fri, Jan 14, 2011 at 1:27:26 PM
Revit Structure 2011 Properties Dialoge box annoyance
Wed, Sep 7, 2011 at 10:02:36 AM
Page generation time: 1.6442
