Forums >> General Discussion >> Revit Project Management >> Unable to Place Components in Linked files
Wed, Aug 10, 2011 at 2:29:46 PM | Unable to Place Components in Linked files
dkglenn
I am having difficulty placing components in my Revit Architecture 2012 model. They are wall hosted (outlets) & floor hosted (floor boxes) components. I have taken the MEP, Base Building, Interiors, and Structural models and linked them into my new file. I have linked them in as overlay. Should I have changed the reference type to attachment? When I go to place my components I recieve the following notifications from Revit and am unable to click any walls or floors: "Click on Wall to place Instance" (outlets) "Click on Floor to place Instance" (floor boxes)
How do I set up these linked files so I can place my families?
Any help would be greatly appreciated!
Wed, Aug 10, 2011 at 2:56:36 PM | Unable to Place Components in Linked files
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
this is tricky and there are alot of posts about this issue. As soon as you link in a model, Revit will only interperate walls as Faces so you have to use 'face based' components. I find it easiest to place face based components in 3D view while using a crop box to cut the wall in half. I've attached a face based outlet family to help, does it work with this?
Wed, Aug 10, 2011 at 3:04:29 PM | Unable to Place Components in Linked files
dkglenn
Face Based makes perfect sense. You would think Revit would inteperate the walls as walls. So unless I copy all of the walls into my own model, having wall/floor hosted families will not serve my needs??
Your duplex worked perfectly fine. Do you know if there is an easy way to convert my wall hosted and floor hosted families to face based or should I just start all over?
Thanks for your help!
Wed, Aug 10, 2011 at 3:08:34 PM | Unable to Place Components in Linked files
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
no way to convert, start by looking through the downloads section here on RevitCity. Otherwise, start from scratch. Its always easier the second time. I've attached another freebie, this time a light switch.
Wed, Aug 10, 2011 at 3:11:59 PM | Unable to Place Components in Linked files
Face based families will host to linked models.
Unable to PICK lines from linked file
Thu, Aug 21, 2014 at 8:47:06 AM
Components "Bring to Front" in linked Files
Thu, Sep 8, 2011 at 9:31:42 AM
tagging linked files
Wed, Oct 19, 2005 at 6:29:00 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Page generation time: 0.8618
