Forums >> Revit Building >> Technical Support >> WIDE LINES
Tue, Nov 29, 2005 at 4:58:34 AM | WIDE LINES
Will9000
4 Stars: 5 Votes
In AUTOCAD we used the polyline (dashed) function to indicate the boundary on the site plan, when using Revit is there a similar command where you can create a very thick line, ive tried the detail wide line but it is far to thin for what i need, any help be much appreciated, Thanks in advance Will
Tue, Nov 29, 2005 at 1:13:56 PM | RE: WIDE LINES
matlock
matlock Avatar
4 Stars: 6 Votes
look under settings- line style - create a new line, call it prop line ( or whatever) then give it a high number (thickness) then it will be available to use as a line.
Tue, Nov 29, 2005 at 4:57:47 PM | RE: WIDE LINES
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
?? Why aren't you using actual properties lines for the boundaries? To have the thick line just change the property line object style.
How to add lineweights to Revit…Instead of the default wide, thin, hidden, e
Mon, Oct 1, 2007 at 10:44:47 AM
titltblocks
Fri, Jan 16, 2004 at 2:43:31 PM
Is Autodesk Revit wide screen compatible
Wed, Mar 28, 2007 at 6:12:31 PM
How to create Roof Sheeting profile 28 metres wide
Thu, Apr 23, 2009 at 8:36:26 PM
Line Work Problem
Tue, Sep 12, 2006 at 1:33:36 PM
Page generation time: 1.2884
