Forums >> Revit Building >> Technical Support >> Shaft Opening Phase Visibility
Tue, Aug 9, 2011 at 9:30:58 AM | Shaft Opening Phase Visibility
zaklee
I've created a shaft opening in phase "New Construction". No matter what I do the shaft is also visible in the existing phase. Is this normal or am I doing something stupid?
Tue, Aug 9, 2011 at 9:58:55 AM | Shaft Opening Phase Visibility
You might have a problem with this because a shaft cuts the floor.  I think you would be better to have a seperate floor sketched in this opening and demo it in the other phase.
Tue, Aug 9, 2011 at 10:28:03 AM | Shaft Opening Phase Visibility
zaklee
Good idea. I employed another low-tech solution: I turned off floor surface patters and then made the shaft opening lines invisible with linework. Good enough for now.
The shaft opening SHOULF work like a door such that the floor is intact in the existing view, shows the opening cut dashed in a demo view and as a void in the new construction view. Similarly, if you were to delete a shaft it should show the extents dashed in the demo view and show a new floor infill in the new construction view.
Sadly, this is not the case...
Tue, Aug 23, 2011 at 9:06:54 AM | Shaft Opening Phase Visibility
Lochnesska
Lochnesska Avatar
The problem of creating a new floor sketch for the new phase is that it will be an entire floor created in next phase and so if I use the graphic filters for the different phases the floor will display as NEW instead of a small piece that is no more there...
What I did when I started thinking about this problem is that I made an opening in the actual floor, I made another one floor that fills the opening and I joined them - so in exi phase there is no difference and in the next phase I simply demolished this part of floor. Better than the phase not-sensitive shaft.
Nessie
Revit 2013
Thu, Mar 15, 2012 at 7:11:40 AM | Shaft Opening Phase Visibility
ihakki
The attached famility will add an opening to a surface and it can be phased.  It also adds an 'X' to the view.  If you don't like the X, edit the family to remove it.  X & Y are instances.  Z is a type parameter.
It's not as cool as a shaft.  In order to link to other floors, turn on underlay, align and lock the edges.  A lot of work, but a workable workaround.
IH
Fri, Sep 9, 2016 at 10:05:09 AM | Shaft Opening Phase Visibility
CombatPotato
CombatPotato Avatar
I use model-in-place voids.  After you create the extrusion, select and cut any surface you want with a single void.  Ceilings, floors, and walls should be easy.  Sometimes, the void opening cannot be edited.  If this happens.  Delete and redraw the void cut.
This phases.
I find it very useful for compelx residential roofs and multi-story buildings.
Any better ideas out there?
Sun, Jan 1, 2017 at 11:31:25 AM | Shaft Opening Phase Visibility
billgilliss
Some Model-In-Place components can be phased this way, some apparently can't. Modeling-in-Place as a void stair component worked for me - it was a stair opening I was cutting, so that made as much sense as any. Way easier to work with than shafts, too, in terms of selection and adjusting.
Mon, Jan 2, 2017 at 9:42:25 AM | Shaft Opening Phase Visibility
It is really easy just to edit the floor sketch and create the hole.
Visibility of Shaft Openings in a detail view
Fri, Apr 17, 2009 at 11:13:42 AM
Cutting a shaft wall
Thu, Nov 29, 2012 at 7:13:39 AM
Undoing Shaft Opening
Fri, Mar 2, 2007 at 12:00:35 PM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Floor and shaft opening issues
Fri, Nov 4, 2016 at 3:41:50 PM
Page generation time: 0.2143
