Forums >> Revit Structure >> Technical Support >> 3D Masking Region?
Mon, Aug 8, 2011 at 4:57:32 PM | 3D Masking Region?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
There is reference in the help file of 3D masking regions, and I understand you need to make a family, but what exactly does this entail?  I basically have an ortho view of a house with a section box around it and I want to mask off certain parts that the box isn't flexible enough to hide.
There isn't much info out there on how to do this...is it just creating a generic family that is essentially a white sheet?
Help appreciated.  Thanks.
Mon, Aug 8, 2011 at 5:48:36 PM | 3D Masking Region?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
well, you can override the objects you don't want to see and remove them from the view, if that's an option.
Otherwise, I don't know of such a thing.  One workaround I've suggested in the past was to overlay a drafting view, on top of a 3D view on a sheet, and then draw masking regions in the superimposed drafting view.
Although a rule of thumb I've learned is that if it seems like there OUGHT to be an easier way to do something... there probably already is.  I haven't installed or played much with 2012 yet, I know they've got 3D annotation and view locks in that release.  Right?
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region
Sun, Sep 14, 2014 at 2:36:26 PM
Masking Region doesn't seem to be masking
Thu, Mar 17, 2016 at 10:59:36 AM
Masking region in roof plan
Tue, Feb 24, 2009 at 3:14:03 PM
Page generation time: 0.1923
