Forums >> Revit Building >> Technical Support >> Underground House
Mon, Aug 8, 2011 at 4:57:04 PM | Underground House
jaycee
I'm designing a new house with Revit 2012 and part of the house is underground.
I need to create a building pad, but I don't want it to go all the way to the surface.
Is there any way to adjust the settings of the building pad tool, or is there another
way of creating a "void" under the ground.
Mon, Aug 8, 2011 at 6:54:41 PM | Underground House
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
There isn't a good way of making a tunnel or similar earth feature.   Building pads will drop an extrusion straight down, as you know.   But you can't cut out a range of dirt.  IE, from pad A to pad B.
The reason being, topography is a 2D surface.  There's no actual depth to earth, in revit.  A hatch is automatically faked in for sections and 3D views, but nothing actually exists for revit to cut.  ultimately, all buildings are floating in space.   My suggestion is to add in an earth hatch manually with a 2D filled region in the sections where it is applicable.
Underground Car Park
Wed, May 29, 2013 at 9:50:10 AM
underground
Fri, Sep 15, 2006 at 2:42:32 AM
Building Gridlines vs Underground Gridlines
Thu, Mar 17, 2011 at 1:49:59 PM
MIRROR entire HOUSE
Thu, Feb 12, 2009 at 6:23:19 AM
Making underground area for parking
Fri, May 9, 2008 at 7:20:05 AM
Page generation time: 4.7131
