14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Add-ins Tab
revit12 explains that to create a batch print...Click Add-Ins tab External panel External Tools drop-down Batch Print.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Add_Ins/0000-Batch_Pr0/0001-Using_Ba1/0004-Creating4
I have no menu tab called "add ins". Where is this found?
You have to install the batch print menu first from the subscriprion site.
When you install this or another ad in the bar will appear.
yes, thanks, found it. great for paper output. But you can't use a batch print to create .pdf sets, unfortunately. We use blubeam for pdfs and either within blue beam or revit, when we print to pdf, we get multiple copies of the same set, seemingly equal to the number of drawings in the set. This can tie you up for hours if the set is many pages long.
Advice on how to print large sets to pdf? Anyone else have this problem?
Look into Xrev. It works great for making PDFs.
No Add-ins tab in my ribbon |
Wed, Oct 17, 2012 at 9:27:01 AM
Add-ins, Add-ons, Plug-ins |
Wed, Aug 31, 2016 at 2:20:36 AM
Revit Architecture 2015 Add-ins |
Tue, Aug 26, 2014 at 9:06:19 AM
add-in tab |
Sun, Dec 8, 2013 at 7:04:56 PM
Revit Add-ins and extensions list |
Tue, Oct 26, 2010 at 2:56:57 PM
