Forums >> Revit Building >> Technical Support >> Adjusting Graphic Display Options for Single Item?
Fri, Aug 5, 2011 at 4:20:57 PM | Adjusting Graphic Display Options for Single Item?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Simple question that surprisingly has not occurred to me until now.
Is it possible to make a single item (say a fireplace family) wireframe while everything else is shaded, or realistic, or something else?
Using Revit 2012.  Thanks.
Fri, Aug 5, 2011 at 4:52:38 PM | Adjusting Graphic Display Options for Single Item?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
sort of.  You can select the item, and if you right click you can use "override graphics in View"  and then by Element, and there can can make an object transparent, AKA wireframe.
You can't use this same system to make an object display as shaded in a wireframe view, however.  Override by element is pretty handy.  You can turn of and on surface hatches, or eliminate individual objects from just one view for artistic reasons, like renders.
Fri, Aug 5, 2011 at 5:01:03 PM | Adjusting Graphic Display Options for Single Item?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Thanks.  Bummer there isn't more control over this.  In Rhino 4.0, I had the same question, but then the good fortune of finding they have a command for just that - changing the visibility of just one object.  *Sigh, chalk one up for the wishlist.
Graphic Display Options Unavailable
Thu, Sep 4, 2014 at 8:00:15 AM
Graphic display options assemblies
Thu, Nov 21, 2024 at 3:35:02 PM
Graphic Display Options Acting Strange
Thu, May 5, 2016 at 4:30:08 AM
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
change colour of shadows
Wed, May 28, 2014 at 3:25:47 AM
Page generation time: 1.9708
