9 Users Online (7 Members):
Forums >> Revit Structure >> Technical Support >> Levels missing from Section?
Hi,
I have an issue with levels not showing up in sections.
We have created a 7 storey large building; the building has several ‘Building Sections’ where all level markers show up OK.
There are also several wall sections, but on two of these level bottom three level markers and dashed line doesn’t show at all, but, for some reason the top two levels are fine.
I’ve checked to see if they are hidden etc but all seems OK.
Any thoughts on what this could be?
In order for the level to show in a section ( column lines too), the datum must cross the clipping plane of the view. Either they are rigt / left ... in which case just uncrop the view and drag them over, or if they may be beyond the view, find a perpindicular view and drag them over.
Finding a perpendicular view worked - Thanks.
Is there any way of 'resetting' the plan datums to cover the whole building extents - or at least viewing the plan extents so that I can check them?
Yes, you can set datums to scope boxes. You can read about those in your HELP
Section Tags missing (again) |
Wed, Aug 26, 2009 at 10:50:38 AM
Levels are missing - I tried all solutions on forums no result |
Wed, Jan 30, 2013 at 10:57:43 AM
Levels missing Revit 2012 [ 1 2 ] |
Mon, Sep 28, 2015 at 3:29:41 PM
19
Section callout missing |
Mon, Dec 16, 2013 at 4:00:09 PM
Levels in Wall Section |
Mon, Jan 26, 2009 at 6:39:01 PM
