15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Cabinet Family which is Wall Hosted
22 Posts No Rating |
Hi everyone,
I have a question when I am fixing some cabinet families. So the cabinet is wall hosted and I need to add a 38 scribe behind it. But since the cabinet is already hosted to the wall it doesn't seem to let me move the cabinet 38 from the wall and add the scribe. Or it doesn't let me host a scribe to the wall then adding the cabinet to that scribe. Maybeit is because the cabinet is still hosted to the wall and isn't part of family. This is an old family that I am fixing up. Is there a way to do this?
Thanks in Advance for the much needed help.
I have not done this but I think you can add a parallel work plane away from the wall, adding a parameter which will allow it to flex. then shift and or rebuild your cabinet. The other thing you could do is create a new cabinet to be hosted by face. Then in the model you could add a workplane parallel to the wall as the surface to attach to.
ok Thanks I will try it out.
Wall hosted components in groups............ [ 1 2 ] |
Fri, Nov 3, 2006 at 8:09:00 AM
15
Wall hosted family can't be hosted on curtain wall?! |
Fri, Oct 22, 2010 at 7:13:04 AM
How do I cut cabinet to host recessed light? Using Revit 2009 |
Thu, Apr 17, 2008 at 10:00:03 AM
Wall hosted family appears in schedule, but not in a room |
Sat, Nov 19, 2011 at 12:58:14 PM
Wall Hosted Family on Curved Wall |
Mon, Jan 28, 2013 at 3:12:42 PM
