Forums >> Revit Building >> Technical Support >> revit structure 2012 add-in "integration with civil 3d": routing error?
Wed, Aug 3, 2011 at 3:29:00 PM | revit structure 2012 add-in "integration with civil 3d": routing error?
WinstonStoskopf
WinstonStoskopf Avatar
I am trying to use the extension "Bridge: integration with AutoCAD Civil 3D" and am receiving the following error message when I try to use the tool:
"The required AutoCAD Civil or AutoCad Civil 3D version is not installed, detected or set as default. AutoCAD process not found."
How do I go about fixing this connection?
My info:
Windows 7 home premium, service pack 1
i7-2630 cpu, 2.0-2.8GHz
8GB DDR3 Ram 1333GHz
nvidia gtx m460 1.5gb
Revit Structure 2012 (student)
AutoCAD Civil 3D 2012 (student)
Sat, Aug 6, 2011 at 6:34:50 PM | revit structure 2012 add-in "integration with civil 3d": routing error?
WinstonStoskopf
ok... finally figured out how to get this to work... was simple as needing to have both revit and c3d running at the same time
Wed, Jan 25, 2012 at 2:56:13 AM | revit structure 2012 add-in "integration with civil 3d": routing error?
nko87
Is this add-in works also with Revit Architecture?
and where to download it?
Error message when importing Robot Millennium buildingmodel
Mon, Mar 5, 2007 at 5:13:15 AM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
"Constraints are not satisfied"
Wed, Jun 7, 2006 at 8:17:24 AM
Print Error "Display Error"
Tue, Dec 20, 2005 at 5:04:34 PM
Page generation time: 2.3051
