19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Can column grids be split?
22 Posts No Rating |
We've been working with the column grid lines going through the plans on our roof layout for every single project we produce in revit. We would normally split the grid to clean up some congested areas in CAD, but were unable to do so in Revit, and that was OK. Unfortunately, the grid lines in this particular project are out of control busy and are really getting in the way.
Can anybody tell me if there is a way to split them? i've checked the posts here, as well as in "help" section in revit, but cannot find an answer. Any suggestions would be great!
We're using Revit Architecture 2012.
Nevermind......figured it out. Set the center segment to none and adjusted the ends to line up where i needed them to. (always learning)
columns grids not recognized |
Wed, Oct 6, 2010 at 9:55:29 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up |
Wed, Nov 23, 2011 at 1:27:06 PM
Eleminate Column Split in Schedules |
Thu, Jul 5, 2012 at 3:05:10 PM
Column Line grids disappear - revit building 2009 |
Mon, Oct 4, 2010 at 4:09:46 PM
Concrete Columns shown split in Column Schedule |
Wed, Aug 19, 2020 at 8:16:11 AM
