8 Users Online (6 Members):
Forums >> Revit Structure >> Technical Support >> Roof opening family
2 Posts No Rating |
Trying to creat a roof opeing family. Opening must be a projection type hole for pipe penetrations. The kicker is I need to be able to tag it so I can put it in a table.
Not sure about creating the family- too many variables to get involved. A generic model roof-based family might work.
Scheduling and tagging is easily accomplished through shared parameters. This is just a text document which contains parameters that can be used on multiple projects. Instead of creating the same parameter over and over and over again you can just select it from the shared parameter file. Then you can tag and schedule these parameters by adding them to the project.
Place a Vertical chimney on pitched roof with opening |
Tue, Jan 6, 2015 at 10:54:30 PM
roof opening |
Tue, Sep 18, 2007 at 11:45:12 PM
Roof Based Family to have void that cuts ceiling |
Mon, Feb 9, 2009 at 12:46:58 PM
Dormer opening problem. |
Wed, Mar 2, 2005 at 1:46:48 PM
Curved Dormer Roof |
Tue, Feb 15, 2011 at 1:31:57 PM
11
