Forums >> Revit Building >> Technical Support >> Combine two text values using a formula
Wed, Aug 3, 2011 at 8:36:29 AM | Combine two text values using a formula
YoshiMPAA
Hi there,
I've created a mechanical vent-family with several types in it. For every type, in Identity Data I've filled in the 'model' and 'manufacturer' text values. Now I'd like to automatically combine these two values in the 'description' field using a formula.
So something like this: 'description' = 'manufacturer' + 'model'
However, I can't get it to work. Does anyone know how to do this?
Wed, Aug 3, 2011 at 8:38:22 AM | Combine two text values using a formula
This question has been asked many times.  There are no text functions in Revit.
Fri, Aug 5, 2011 at 2:30:21 AM | Combine two text values using a formula
YoshiMPAA
Not an answer I was looking for, but thanks anyway for your reply.
Sun, May 13, 2018 at 5:57:05 PM | Combine two text values using a formula
jlumley
Use 'Combine Parameters'
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
String Values in Formulas
Wed, Dec 4, 2013 at 10:38:12 PM
Can a shared text parameter conconate other text parameters
Tue, Dec 29, 2009 at 12:58:28 PM
Formula to not exceed value in family
Tue, May 20, 2008 at 12:34:26 PM
Combine Discipline
Fri, Jun 17, 2016 at 6:54:42 PM
Page generation time: 0.2845
