Forums >> Revit Structure >> Technical Support >> Delete (title block) family category parameter
Wed, Aug 3, 2011 at 5:35:49 AM | Delete (title block) family category parameter
gprakash
Hi,
Is there any way to delete a category parameter in a sheet family?
I searched on this topic and those related are old posts which says impossible. Just trying my luck on 2012 version!
For example, I need to add a shared param for "Checked by" in Project Information. When I add a sheet within a project, ultimately there will be two similar parameters but the family category parameter will be redundant.
If deletion is not possible, is there a way to link both params?
Thanks.
Wed, Aug 3, 2011 at 10:04:50 AM | Delete (title block) family category parameter
TKennedy
4 Stars: 8 Votes
You can't delete a system parameter, but linking the parameters may be possible. First, why are you re-creating the system parameter? Why not use it?
Thu, Aug 4, 2011 at 12:55:25 AM | Delete (title block) family category parameter
gprakash
Thanks for the reply.
That was a specific requirement here - to have 'Checked By' as Type parameter since that system param is Instance.
Anyway, the user can now select all sheets in project browser and enter the param value just once. Additional shared param can be avoided and system param will be used as you suggested.
Thanks.
Shared Parameter In Annotations
Thu, May 24, 2018 at 6:11:56 AM
Title Block Parameter
Wed, May 5, 2010 at 2:05:45 AM
Add Parameter to Family Category - View Title
Tue, Jan 17, 2012 at 2:28:48 PM
How to delete Title Blocks
Thu, Feb 28, 2013 at 9:34:03 AM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Page generation time: 5.3400
