26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Nested Family Visual Issue
209 Posts No Rating |
So i loaded a window family into another family and then loaded that one into a project. The issue is in plan view it is showing my entire frame of my nested window family rather than cutting though it to show the window? Anyone know why its doing this and is there a way to fix it?
Edited on: Mon, Aug 1, 2011 at 5:58:11 PM
Edited on: Mon, Aug 1, 2011 at 6:17:49 PM
I've had the same problem in the past; try playing around with the view range in your window family. Make sure that your cutting through the window with default sill height (ensure that you are using 'Hidden Line' display while doing this). Then reload it into your project.
97 Posts No Rating |
Thanks for this, I had the same issue.
Doesnt seem to work for me. My window family view depth is cutting through the window and set hidden line. When I load that into my next family it shows fine but when yo load it into the project it shows the entire frame system. It looks like it entirly ignores the view depth of the nested family and looks at it as an entire system like stairs.
Attached is the example of my issue. The nested family 4 is the window family it is placed south of the actual window itself as a component.. When you load it into a project you will see what i mean
how to have text on a nested family show when its in the family it is nested to |
Fri, Jun 5, 2009 at 3:30:32 PM
Nested Family Count in Table |
Mon, Jan 15, 2018 at 11:47:52 AM
Nested family always vertical? |
Mon, May 16, 2011 at 2:55:02 PM
nested family rotation |
Tue, Sep 3, 2013 at 1:25:41 PM
Issue with annotation nested with generic model family |
Wed, May 25, 2016 at 9:46:10 AM
