Forums >> Revit Structure >> Technical Support >> Walls not attaching to imported roof
Sun, Jul 31, 2011 at 5:57:21 AM | Walls not attaching to imported roof
mcfetrmatt
Hi guys,
I have created a roof in Rhino (using T-splines) and exported it as a .SAT into revit mass then imorted it into my revit project and turned it into a roof. Only the wall wont attach to it?? says, "Can't keep wall and target joined". I have tried this with a basic roof and it works so why wont this imported roof design? As far as I know i have no reason to believe that revit thinks that this is any different to any normal roof??
Any ideas are welcome Smile Thanks!!
Mon, Aug 1, 2011 at 9:59:28 AM | Walls not attaching to imported roof
emgeeo
3.5 Stars: 7 Votes
I think I tried what you are trying a while back with the same result.
Fri, Aug 5, 2011 at 7:03:07 PM | Walls not attaching to imported roof
mcfetrmatt
Thanks Emgeeo, good to see im not the only one,
Does anyone have any ideas? This is really frustrating me because I cannot understand why it doesn't work?? Even when I create a 'simple' roof get it in and create it as one roof (ie. not in parts) it still doesnt work.
I have found that sometimes changing the material has worked, any ideas as to why that may be the case?
Thanks, any comments appreciated
Fri, Aug 5, 2011 at 7:08:07 PM | Walls not attaching to imported roof
mcfetrmatt
The attached images dont seem to be attaching..?? So here is another go
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
exterior walls above a lower roof
Sat, Feb 26, 2011 at 1:52:16 PM
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:44 PM
Attaching a gutter to a wall instead of a roof
Tue, Feb 21, 2017 at 10:16:44 AM
Difficulties with imported 3D roof object
Wed, Mar 24, 2010 at 10:12:11 AM
Page generation time: 0.8654
