Forums >> Revit Building >> Technical Support >> Cabinet Handle sweep wont lock to vertical RP
Fri, Jul 29, 2011 at 1:01:26 PM | Cabinet Handle sweep wont lock to vertical RP
keyaggie
Withing a cabinet family I have moded a sweep (for a handle).  I can keep the sweep (circular) locked to the center of the door face various cab. widths but cannot lock it to the vertical rp for various cab. heights.  Any suggestions??
Fri, Jul 29, 2011 at 1:08:04 PM | Cabinet Handle sweep wont lock to vertical RP
Did you use reference planes to define the limits of the sweep path?  ... Or at least a reference plane for the handle location with the sweep path dimensioned off that?
Sat, Jul 30, 2011 at 7:24:19 AM | Cabinet Handle sweep wont lock to vertical RP
keyaggie
After much trial with no success, I replaced the sweep with a handle family and it locked perfectly.  Part of the trial/error
was what template to use for the handle family, where to place it etc. - finally worked it out. Smile Thanks
sweep wont wrap my inplace component
Thu, Sep 29, 2011 at 3:28:09 PM
Formula: Yes/No
Tue, Aug 25, 2009 at 11:53:04 AM
How do I cut cabinet to host recessed light? Using Revit 2009
Thu, Apr 17, 2008 at 10:00:03 AM
Curved Cabinet front
Fri, Jan 6, 2012 at 11:33:34 AM
Roof Sweep does not follow vertical on dormer
Fri, Aug 4, 2006 at 11:00:44 AM
Page generation time: 1.8491
