Forums >> Revit Building >> Technical Support >> Floorplan invisible
Fri, Jul 29, 2011 at 11:12:18 AM | Floorplan invisible
B0bTheBuilder
Hi
I have a problem with viewing a floorplan. It is something that suddenly just happend: the ground floor floorplan is invisible (you can enter the floorplan, but there is nothing), while all the others are fine.
I've tried to delete the floorplan view and add it again, changing de settings to default, changing the visibility and different zooms - nothing.
Thx
Fri, Jul 29, 2011 at 11:17:40 AM | Floorplan invisible
Did you create a new plan by selecting from the ribbon - View / plan views / floor plan then select your level?  (DON'T DO IT ANY OTHER WAY)
Fri, Jul 29, 2011 at 11:20:23 AM | Floorplan invisible
B0bTheBuilder
Jep
Fri, Jul 29, 2011 at 11:23:12 AM | Floorplan invisible
Do you have a building?  Everything is there in 3D?
Cut a section from the second level and select some items from the first level.  What phase are they?
Fri, Jul 29, 2011 at 11:28:09 AM | Floorplan invisible
B0bTheBuilder
Jep, it says "New Construction". I can see the ground floor from the underlayered layer in the 1st level - don't know whether its to any help? Or else is there a way to move a whole project from one file to another? Just to see whether its because it's because the file is corrupt..
Fri, Jul 29, 2011 at 11:35:44 AM | Floorplan invisible
I doubt the file is corrupt.
Please post a section through the building that shows the elements and the floor levels.
Fri, Jul 29, 2011 at 11:54:43 AM | Floorplan invisible
B0bTheBuilder
Fri, Jul 29, 2011 at 12:21:14 PM | Floorplan invisible
We need to see the floor level indicators....I want to see that the ground floor level is really at that level.  No just Notes but the level that has the eleveations of each level.
Edited on: Fri, Jul 29, 2011 at 12:21:52 PM
Fri, Jul 29, 2011 at 12:27:03 PM | Floorplan invisible
B0bTheBuilder
Don't if this one helps?
Fri, Jul 29, 2011 at 12:29:55 PM | Floorplan invisible
B0bTheBuilder
And here is the invisible floor plan..
Fri, Jul 29, 2011 at 1:05:35 PM | Floorplan invisible
#11
Does your project have a scope box?
Make sure your plan view is not cropped and there is no scope boz, then zoom a.
Fri, Jul 29, 2011 at 1:47:20 PM | Floorplan invisible
#12
B0bTheBuilder
No scopebox - nothing.. (see picture)
Invisible Lines
Thu, Jan 30, 2014 at 7:46:10 AM
Make annotation on wall-mounted family show on floorplan
Wed, Nov 12, 2008 at 1:41:40 PM
Technical assistance floor plan details missing from view but not sheet
Mon, Mar 6, 2017 at 8:42:34 PM
scale floorplan
Tue, Mar 18, 2008 at 10:31:34 PM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
Page generation time: 1.0310
