Forums >> Revit Building >> Technical Support >> Foundation Wall with Brick shelf (Layered)
Fri, Jul 29, 2011 at 11:09:23 AM | Foundation Wall with Brick shelf (Layered)
JBarron222
Does anyone know how to get this to work?
I have a layered wall that is just 2 layers of Cast-In-Place Concrete.  The exterior layer is unlocked so that it can be dropped to create a brick ledge.
When 2 segments of this same wall type come together at a corner, I cannot get it to wrap properly if the ledges are at different elevations (see image 1)
I want the 12" thick portion (or interior portion) of the wall to have a typical corner join even if the 5 1/2" portion (or brick shelf portion) are at diffent heights...(see image 2)  Image 2 was acheived using 2 different walls, a 12" wall with a 5 1/2" wall next to it.  I'd like to get the same result by using a single, layered wall type
can this be done?
Fri, Jul 29, 2011 at 11:33:00 AM | Foundation Wall with Brick shelf (Layered)
If the ledge steps near or at the corner, I doubt that you will be able to control this.  Instead I would try, letting the high side be the setting for the wrap at the corner, then adding an in-place void family placed to cut the ledge how you want.
Brick or Stone Overhang
Tue, May 8, 2007 at 11:40:16 AM
Wall Opening
Mon, Oct 19, 2009 at 9:39:12 AM
Slab Foundation
Thu, Jan 31, 2008 at 1:59:46 PM
Door families not flexing with layered walls
Wed, Jul 13, 2011 at 6:50:32 AM
Foundation Wall Problem
Wed, Oct 12, 2011 at 5:57:25 PM
Page generation time: 1.1671
