Forums >> Revit Systems >> Technical Support >> Pendant sprinkler head not hosted
Thu, Jul 28, 2011 at 12:04:48 PM | Pendant sprinkler head not hosted
jcrocco
3 Stars: 1 Votes
Is there a pendent sprinkler head that anyone has that is not hosted?  I am showing existing heads in a warehouse and there is no ceiling.  The ones that come with MEP2012 really are genric. LOL  Seems all families on download are hosted.
Thu, Jul 28, 2011 at 12:23:09 PM | Pendant sprinkler head not hosted
There are unhosted ones on the AutoDESK SEEK site.
Thu, Jul 28, 2011 at 1:47:37 PM | Pendant sprinkler head not hosted
jcrocco
3 Stars: 1 Votes
I looked there, and I searched under Revit and Sprinkler head and only found 13 items, none of which were a sprinkler head, they were detail or flexheads.  If you know of one could you provide a link?  needs to be for MEP, or maybe I can take an architectural one and modify it by adding a connector if thats would work.
Thu, Jul 28, 2011 at 3:03:34 PM | Pendant sprinkler head not hosted
Your right - sorry.
Why can't you use the sorry for the text size - cut and paste from site
Dry System Upright Sprinkler, 5.6 K Factor, 30 GPM Flow Rate, 2" Overall Length, 1" Nominal Diameter, 7.0 psi Pressure Drop ... and modify its parameters.
Edited on: Thu, Jul 28, 2011 at 3:04:01 PM
Thu, Jul 28, 2011 at 3:16:53 PM | Pendant sprinkler head not hosted
jcrocco
3 Stars: 1 Votes
Well, it needs to be a pendent.  Can an upright be used for a pendent, meaning can it be rotated?  It also has to not be hosted.
Thu, Jul 28, 2011 at 3:25:09 PM | Pendant sprinkler head not hosted
Edit the family and turn it around.....
Thu, Jul 28, 2011 at 3:40:13 PM | Pendant sprinkler head not hosted
jcrocco
3 Stars: 1 Votes
I didnt know it could be rotated, but more importantly I didnt know you can take a familty that is hosted and make it non hosted.
Difference between selecting object in 3D view and ceiling plan view?
Sat, Jul 30, 2011 at 11:30:06 AM
Creating a Sprinkler Tag and Schedule
Mon, May 24, 2010 at 12:08:43 PM
MEP QUERY - Sprinkler system showing route in angle
Tue, Mar 3, 2009 at 10:02:18 PM
Pendant light placement
Wed, Sep 19, 2007 at 4:03:08 PM
sprinkler heads
Tue, May 5, 2009 at 8:32:09 AM
Page generation time: 0.6303
