Forums >> Revit Building >> Technical Support >> How to assign a standard family type to an In-Place object?
Wed, Jul 27, 2011 at 4:17:05 PM | How to assign a standard family type to an In-Place object?
kayvan
Hi All,
I am fairly new in Revit and am trying to self learn in from scratch so please forgive me if that may sound obvious.
I make an object using in-place family (let say a floor for example) but I am wondering how can assign a standard floor type to it? Or if it isn’t possible then how should I define a structure for it in way that I’ll be able to edit its family type later on?
Many thanks
Kayvan
Mon, Aug 1, 2011 at 9:49:59 AM | How to assign a standard family type to an In-Place object?
emgeeo
3.5 Stars: 7 Votes
You cannot change and in-place family to another family.  In-place families should be used (in general) for only single-instances of unique geometry.
Mon, Aug 1, 2011 at 9:52:41 AM | How to assign a standard family type to an In-Place object?
Check this out and see if it helps.  I have not yet looked at it.
http://whatrevitwants.blogspot.com/2011/07/save-in-place-family-as-rfa-for-use-in.html
Mon, Aug 1, 2011 at 10:33:57 AM | How to assign a standard family type to an In-Place object?
emgeeo
3.5 Stars: 7 Votes
i stand corrected...
Tue, Aug 9, 2011 at 5:16:04 PM | How to assign a standard family type to an In-Place object?
kayvan
Thanks for replies, therefore emgeeo please correct me if I am wrong: for example if I make a floor by in-place then when I make section through it I will see its construction just as unify single object.
Any way of assigning Family and type to model in place ?
Fri, Sep 14, 2012 at 8:01:09 AM
Create Roof Family Object
Mon, Nov 21, 2005 at 7:10:42 PM
is there any way to transfer family object to instance object or something like
Wed, Jun 1, 2011 at 7:10:55 AM
line style in plan view
Thu, Mar 4, 2004 at 12:47:43 PM
assign different subcategory to labels?
Wed, Feb 16, 2011 at 3:11:06 AM
Page generation time: 0.9924
