Forums >> Revit Systems >> Technical Support >> revit architecture 2012 installation
Tue, Jul 26, 2011 at 10:17:30 AM | revit architecture 2012 installation
Bry80
HI!,
just installed Revit 2012 and had this message appearing while opening:
" The default templates file you have specified does not exsist.
To change the default file path form the application menu select OPTIONS and the file location...
I read somewhere if templates are missing I can just download templates and families of revit 2011...is that correct, are they gonna work fine?
In case it is, which is the correct locations for them? do I need to create a folder?
or do I need to reinstall revit?
is the following location correct for families?
c:\ProgramData\Autodesk\RAC 2012\Family Templates\English_I   or
(What the difference between .rft and .rfa files?)
and  for templates?
I'm quite confused I'm not really into installation, have had someone to help me but he's not really into revit either..
Hope someone is patient enough to help me.
Many thanks.
Tue, Jul 26, 2011 at 10:31:16 AM | revit architecture 2012 installation
If you have installed the program correctly, the template files exist, it is just your paths that are wrong.  When you installed, you were asked where you wanted your library files.  Makes sure you know where that is.
Now, in Revit, click on the R and goto the bottom - options.
Under the file locations tab, there are 3 paths you should set. -
  1. The project template file location
  2. your default local save location
  3. Your family template locations
Set those and you should be fine.
Tue, Jul 26, 2011 at 10:39:02 AM | revit architecture 2012 installation
Bry80
thanks for your reply..
Probably I need to re-install it then..don't see templates... just some in here c:\ProgramData\Autodesk\RAC 2012\Family Templates\English_I
Fri, Sep 23, 2011 at 4:39:25 PM | revit architecture 2012 installation
stamenvalchev
Ermmm, might be a bit too late in your case but you totally don't need to reinstall Revit. Just get/download/create some template files and then assign them as default templates for Revit.
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
Revit Architecture 2012 Library?
Sat, Sep 1, 2012 at 11:21:01 AM
Import full Civil 3D 2012 model in Revit Architecture 2012
Thu, Jan 26, 2012 at 6:23:35 AM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:18 PM
Conceptual Mass: Revit Architecture 2012 (Trial V.)
Mon, Jun 30, 2014 at 7:20:05 AM
Page generation time: 1.7984
