Forums >> Revit Building >> Technical Support >> Symbols
Fri, Nov 25, 2005 at 5:09:17 PM | Symbols
Steve1959
Having no success entering text symbols such as Degree/Diameter etc. I have been told for a degree symbol I hold the ALT key & enter the sequence 0186. Is this correct & if so any clues on why it wont work for me? I have had no luck searching for info on this subject, would like to now where the text symbol keynote list is stored. RGDS Steve
Fri, Nov 25, 2005 at 5:20:55 PM | RE: Symbols
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The codes are store in the windows character map. you have to type the numbers on the number pad in order for it to work.
Fri, Nov 25, 2005 at 5:29:24 PM | RE: Symbols
Steve1959
That worked! Thank you Mr Spot.
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
symbols, detail components
Mon, Jan 23, 2012 at 6:35:40 AM
SYMBOLS
Fri, Mar 6, 2009 at 11:02:48 AM
Electrical symbols - scaling
Tue, Feb 5, 2013 at 7:18:56 AM
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
Page generation time: 0.0321
