Forums >> Revit Building >> Technical Support >> NURBS import
Fri, Nov 25, 2005 at 6:34:33 AM | NURBS import
alfa
i usually use VIZ or MAX to generate complex surfaces. the question is: how can i import them in revit??? VIZ does not have an acis .sat export option......
Mon, Nov 28, 2005 at 10:33:40 AM | RE: NURBS import
wizzleteet
A: Check and make sure that the .dwg export saves Nurbs. As I understand it the newest 2006(2005?) dwg has this capability.... B: find acis out plugin for 3ds Max/VIZ, can't seem to find a free one, so maybe look at polytrans f.i. C: export as .igs open with Rhino3d, export from rhino ....
misleading import of NURBS!!
Wed, Oct 3, 2007 at 5:19:04 PM
Nurbs Roof Import
Thu, Feb 16, 2006 at 2:32:58 PM
REVIT and NURBS
Sun, Mar 19, 2006 at 9:34:11 PM
Texture mapping for imported objects
Sat, Jul 29, 2017 at 9:33:53 AM
scan polymesh import to revit
Wed, Apr 9, 2008 at 11:34:10 AM
Page generation time: 2.7147
