Forums >> Revit Systems >> Technical Support >> Invisible room tags (Revit MEP)
Fri, Jul 22, 2011 at 12:58:58 PM | Invisible room tags (Revit MEP)
Justin8304
I am using Revit MEP and trying to place room tags into a building that is a xref of Revit architecture. As I am about to place the tags, I noticed that it reads the original room names from the Revit Architecture file. But when I click to place the room tag an error pops up saying that the tag is not visible in the current view (which is a floor plan so it should). I tried ajdust my visibility/graphics, the view range, and my worksets are all set up as they should be. I tried utilizing the space naming utility but this was unsuccessful becuase the spaces would load but, again, there were no room tags. Does anyone know anywhere in the program where my views or visiblity might not be set up right, or know the sollution to this problem???
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Room Tags in Linked File
Mon, Aug 23, 2010 at 6:48:45 PM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
room tags revit 2013
Tue, May 14, 2013 at 5:22:15 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Page generation time: 5.4885
