25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Doors are missing in plan
6 Posts No Rating |
We downloaded an adustable door from RevitCity to have the capability to adjust the door swing and we are having issues displaying it in plan view. We have a multi-level building that varies 6 ft over the entire project. The doors were all added in on the 0'-0" layer. We have created views for each of the different levels so that we can drop in model compenents to display properly in Interior Sections and Elevations. The problem is now that I am moving the doors to be located on their correct level, The frame shows up, but the doors disappear in plan. I have seen that the cut plane in a family can be different than the cut plane in a plan view, but I do not see anyplace where I can change this. Is this the problem, and if so, how do I fix it? Or is it something else entirely?
post a screen-shot with a door in plan, and both the type and instance properties clearly visible. What you are describing is a bit difficult to understand.
Walls, Windows Furniture ect missing on level2 plan |
Sun, Aug 16, 2009 at 5:42:55 AM
Doors on plan vs elevation |
Thu, Jan 14, 2016 at 7:48:16 AM
Structural plan is missing from View tab> plan views |
Mon, Apr 29, 2013 at 8:04:26 AM
Importing IFC into Revit 2020. Windows/Doors not showing in plan/elevations/sect |
Tue, Feb 4, 2020 at 6:15:58 PM
Doors in plan |
Tue, May 13, 2014 at 1:44:50 PM
