Forums >> Revit Building >> Technical Support >> Recovery file is typicall significantly smaller
Thu, Jul 21, 2011 at 3:17:45 AM | Recovery file is typicall significantly smaller
emgeeo
3.5 Stars: 7 Votes
anyone else notice this?
http://screencast.com/t/t98IvdCkjH
what's the reason?  I am happy to have a reduced file size, but also a little nervous.
Thu, Jul 21, 2011 at 6:47:32 AM | Recovery file is typicall significantly smaller
coreed
coreed Avatar
4 Stars: 16 Votes
i guess that is the info that couldn't be recovered. i would like to know also.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Jul 21, 2011 at 7:06:14 AM | Recovery file is typicall significantly smaller
That's a big change on such a small file but it might be attributed to views.
Revit's file size is partially dependent on the view it is saved from.... I think it stores that screen.  We ask all of our users to save their projects from a project information legend view.  This is a small view and when the project is pre-viewed or opened, current project status information is displayed.
Never save from tiled views because that will give you the largest file.
Thu, Jul 21, 2011 at 9:21:50 AM | Recovery file is typicall significantly smaller
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
It could also be that the recovery file is compacted upon creation and a possible data purge.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Jul 22, 2011 at 9:24:44 AM | Recovery file is typicall significantly smaller
emgeeo
3.5 Stars: 7 Votes
We have a Save Here sheet as well (actually saving there is another story) but I don't think that's the issue.  Our current template size is around 5MB.  I can actually pinpoint what causes the error- it's invariable dimensioning in a section perpendicular to (or almost perpendicular to) a grid not exactly N/S or E/W...
Anyone else have that issue?
Tue, Jul 8, 2014 at 3:51:20 AM | Recovery file is typicall significantly smaller
Graeme6226
This is a very old thread but just wondering if anyone has a more detailed answer to this.
I have noticed the same file size differences and dont like using the recovery file as I feel information has been lost somewhere.
Most recently I saved a recovery file that was 42,776kb but my main file was 55,184kb.
I dont want to risk using the recovery file to find in a few days time things are missing in the model! This just means that I back track a few hours and repeat the work lost but I am just thinking this defeats the entire purpose of saving a recovery file>
Any thoughts!!
Tue, Jul 8, 2014 at 8:06:35 AM | Recovery file is typicall significantly smaller
As you work on a project, the file size grows but some of it is just junk.  That is why compressing the file can make a significant difference.  You will see that difference when you compress a file or simply making a new local.  The local will be smaller than the central.   A recovery file is simply a new local.
We have nver seen a loss of data in a recovery file except for possibly our last action.  I would trust the recovery if you have a lot of local work done since your last save.
Tue, Jul 8, 2014 at 8:14:47 AM | Recovery file is typicall significantly smaller
Graeme6226
Excellent, you have restored me confidence Smile
I shall save alot of time now, not having to back track.
Thanks very much for you prompt reply.
Recovery Files smaller file size than original files
Wed, Oct 31, 2012 at 4:40:12 AM
Recovery File
Fri, Nov 2, 2012 at 8:51:18 AM
recovery file not saving changes
Fri, Sep 16, 2005 at 7:23:01 PM
File recovery and backup Best Practices
Mon, Jul 8, 2013 at 11:15:27 PM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
Page generation time: 0.4181
