Forums >> Revit Building >> Technical Support >> Sheet Label to Drawing List
Sun, Jul 17, 2011 at 11:42:45 PM | Sheet Label to Drawing List
dbartlett
I have a Revit problem that seems straightforward, but not to me at the moment...
We have a label in the title block. The label comprises 3 parameters concatenated with “-“ separators:
  • Project Number
  • Discipline
  • Sheet Number
eg: 123456789-A-001
 Of those 3 parameters
  • Project Number: is inbuilt Revit Project Information
  • Discipline: is Shared Parameter
  • Sheet Number: is inbuilt Revit Project Information
In our Drawing List, for each sheet listed, we want one field to display the full label value: 123456789-A-001
 Any suggestions?
Mon, Jul 18, 2011 at 7:20:24 AM | Sheet Label to Drawing List
Currently Revit does not support text manipulation so there is no automatic way of doing this.  Wish there was......
Thu, Sep 8, 2011 at 10:22:26 PM | Sheet Label to Drawing List
DezignViz
I have the same question/need. Fine if we have to kluge the concatenation aspect. However, my bigger question is, is there any way to even get the Project Number itself to appear in a sheet list for multiple entries? If not directly, are there any best practices folks have used to deal with this situation?
Fri, Sep 9, 2011 at 7:12:53 AM | Sheet Label to Drawing List
Add a new shared parameter to the project and assign it to sheets.
Fri, Sep 9, 2011 at 7:51:14 AM | Sheet Label to Drawing List
DezignViz
As a secondary Project Number? Just don't use the built-in one, or is there a way to have it read the value from the built-in one?
Fri, Sep 9, 2011 at 9:44:27 AM | Sheet Label to Drawing List
When you add parmeters to a project, you can pick what categories they are assigned to, in this case project and sheets would work for both.  It is not the same parameter as the default and you would not want to confuse the two so I suggest a different name.
Fri, Sep 9, 2011 at 2:56:26 PM | Sheet Label to Drawing List
DezignViz
OK, thanks.
Column sizes in the Drawing List
Mon, Jul 13, 2009 at 2:24:16 PM
Sheet List
Mon, Jan 7, 2013 at 4:35:52 PM
Revit Drawing List
Mon, Jul 28, 2008 at 5:54:01 AM
Revisions in Drawing List
Tue, Mar 6, 2012 at 2:37:26 PM
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Page generation time: 3.4255
