Forums >> Revit Building >> Technical Support >> View Templates Linked to Elevation Tags
Fri, Jul 15, 2011 at 10:47:23 AM | View Templates Linked to Elevation Tags
sharris2909
Is there a way to link a specific view template to an elevation or section tag.  So when you place that tag (Elevation/Section) the default view template is set to a specific view template you have created?
Fri, Jul 15, 2011 at 10:52:33 AM | View Templates Linked to Elevation Tags
TKennedy
4 Stars: 8 Votes
Apply the view template you want to be the default to a view. In the dialogue box where you pick which view template to use there is a "use this template for new views" (I forget the exact wording). That should work.
Fri, Jul 15, 2011 at 1:05:51 PM | View Templates Linked to Elevation Tags
sharris2909
Thanks for the suggestion and that works great, except it only uses the template you have applied last.  IE It can't disinguish between an interior elevation and a wall section.  If you used the wall section template last then that is what is uses if you next choose a interior elevation.
Any thoughts on how to change this?
Tags linked in more than one view
Fri, Feb 27, 2009 at 6:21:47 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
View Templates and V/G Overrides, Revit Linked Files
Sat, Jul 9, 2016 at 12:37:06 PM
Transfer Project Standards - View Templates
Mon, Aug 29, 2011 at 12:03:03 PM
can't see elevation tags in one view
Tue, Aug 30, 2016 at 1:34:14 PM
Page generation time: 2.0581
