11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Void Sweeps
208 Posts No Rating |
Hi all,
I have created a void sweep to cut the edge of my roof to hug my fascia correctly.
I would like to edit this void sweep. Is there a quick way to easily locate these suckers?
I know that all you need to do is hover over the void sweep and then click it to begin the editing process however, it is very rare that I am able to hover over the void sweep and have it highlight.
It is a hit and miss affair. Mostly once I have created the void sweep I cannot highlight it to edit if I need to.
cadjockey
You can also select it throught the family browser....
Hi Mr Spot,
That's what I thought however, this works for some and not for others. I do not think I have created the void sweeps any different from each other.
Is there a setting I need to have on/off while I create these void sweeps so that later I am able to browse them?
I note that while browsing the void weeps the 'make element editable' option is not available.
cadjockey
15 Posts No Rating |
i would maybe try making a small solid shape, very small, along with the void, so that you know where it would be in relation to the void, therefore making it easier to select. or, do that leftwards select thing where it selects everything within the selection box and then use the selection filter to select the void.
i could be wrong, but that is what i would try.
When selecting voids that are cutting something, you need to however over the cut edge of the element the void is cutting to select them.
Hi Enran,
I'll give that a try.
Mr Spot,
Yes that is correct. I am able to do this however, it very very random and mostly once I have created the void sweep I can no longer find it. No matter how much I run my cursor over the cut edge.
It is very frustrating.
cadjockey
pattern issue-void cutting through wall and sweeps |
Fri, Sep 23, 2011 at 2:24:08 PM
Selecting Invisible Void Sweeps |
Wed, Jan 28, 2009 at 4:23:09 PM
Void Sweeps within Window Family |
Tue, Mar 25, 2008 at 10:26:05 AM
Wall reveals and sweeps being 'over-ridden' by wall based void family. |
Fri, Jan 22, 2010 at 4:39:24 AM
Turning off sweeps in an elevation view? |
Mon, Dec 6, 2010 at 9:05:03 AM
