Forums >> Revit Building >> Technical Support >> Duplicate Elevations / Overlapping Tags Mess
Thu, Jul 14, 2011 at 1:35:37 PM | Duplicate Elevations / Overlapping Tags Mess
jamiew
After I issue a set of drawings to the contractor, I may need to revise/re-issue some of my interior elevations and put them on a smaller sheet with a smaller border (otherwise known as an SKA).  I usually Duplicate the Interior Elevation View - including detailing, and then drag it to an SKA sheet.  Now, this creates two elevation tags in the same place on my Floor plan, one on top of the other.  They usually make each other illegible, because the 2nd tag displays a different sheet #.
After multiple SKA's issued at breakneck speed, my floor plan is now illegible.  Is there a way to Isolate all of the SKA views, and shut them off quickly.  Right now I am using a filter (filter views by Sheet # contains "SK").  But, can't I just put all of the SKA stuff in a seperate workset?
Revit Architecture 2011
Autodesk Revit MEP 2015
Thu, Jul 14, 2011 at 2:36:52 PM | Duplicate Elevations / Overlapping Tags Mess
I believe you will find (as you already have) that your process will get you in real trouble.  It is a CAD thought process.  Take a look at this thread, it will solve your problems:> http://www.revitcity.com/forums.php?action=viewthread&thread_id=20858&start=15
Duplicate room tags overlapping
Mon, Oct 30, 2006 at 4:39:13 PM
overlapping pads - is it possible?
Sat, Jul 28, 2018 at 2:00:32 PM
View titles lettered for interior elevations, cannot duplicate...
Wed, May 31, 2017 at 10:43:39 AM
Duplicate elevation
Wed, Jan 23, 2008 at 11:45:55 AM
Duplicate views create duplicate callout tags in referring views...
Fri, Mar 9, 2012 at 1:37:25 PM
Page generation time: 0.8493
