Forums >> Revit Building >> Technical Support >> REV 2009 Spot elevations
Thu, Jul 14, 2011 at 12:56:37 PM | REV 2009 Spot elevations
tmassey
tmassey Avatar
Hello...in the spot dimension elevation element there are 4 settings for display elevation. what is the difference between actual selected elevation and top elevation?
e.g. site plan with f.f. height at 100. drop 2" to sidewalk with 2% slope to T.O.C.
I am trying to calc the T.O.C. at the sidewalk 5' from face of building it won't select the 2" drop height 99.83 it choses the 100.00 F.F.calc
another question is the single upper value. if our f.f. height is set to 100 or 0.00 why would the upper value display at 99'11"?
this is a big one so thank you to all who read this or answer..
cheers
Using Revit Architecture 2012
Thu, Jul 14, 2011 at 1:11:21 PM | REV 2009 Spot elevations
tmassey
tmassey Avatar
I figured out the upper value display..it shows the actual elev datum height..i overcomplicated this. I do need to how to get the datum to reference different heights and not default to the F.F. height
Thu, Jul 14, 2011 at 1:27:44 PM | REV 2009 Spot elevations
How did you do your sidewalk.  Spot elevations work for sloping floor slabs and if you spit your topo and assigned concrete to it but it will not work in plan on ramps.
REV 2009 titleblock arch stamp
Thu, Jun 30, 2011 at 3:39:35 PM
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:28 AM
3d dimensions Rev 2009
Wed, Jun 22, 2011 at 12:40:13 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Page generation time: 2.9575
