28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Can't blend two similar sweeps into mitred corner
7 Posts No Rating |
I have an existing door I am trying to model. In 30 locations in the building where the opening has the same profile that wraps the opening. In two locations the 7" profile is modified to a 5" profile. (see attached) Is there a way to get the profiles to blend at the mitre? I would like to find a quick easy way, as opposed to make the sweep out of three different profiles.
Using Revit Arch 2011
You want two differnt profiles to miter at 45 ? Can't be done in real life or revit.
You can't have 3 different profiles in a sweep.
.....Or did you mean three diiferent sweeps?using 3 different profiles? Seems to me that would be simple to do with a family.
7 Posts No Rating |
the profile has three similar components (in real life) the outer and inner bands are identical the filler blocking is variable. I like the idea of doing the entire profile as a nested family! then I can control the variable instance of the blocking filler.
thanks for the help, I'll let you know if it works!
7 Posts No Rating |
I was able to get the trim to flex the way I needed it. It looks great in elevation/hiddenline. However, I can't get it to respond to material selection, or to cut properly in Plan View.
Intersecting sweeps |
Thu, Sep 15, 2005 at 9:30:35 AM
corner boards |
Sun, Dec 18, 2005 at 4:50:54 PM
Parapet wall sweeps at corners with different wall thicknesses |
Thu, Feb 7, 2013 at 11:00:38 AM
Corner Trim with Vertical Sweeps |
Thu, Aug 31, 2017 at 2:32:51 PM
Butt-jointed curtain corner - no mullion? |
Sun, Jun 28, 2009 at 8:15:44 AM
