Forums >> Revit Building >> Technical Support >> Material hatch will not print gray, only black
Wed, Jul 13, 2011 at 4:19:47 PM | Material hatch will not print gray, only black
jnpowell
I have a custom aluminum curtain wall panel which I would like to show with a light gray hatch in elevation.  I have changed the surface pattern for its material to Revit's native "Aluminum" pattern and changed the color to a light gray.  It shows up on my screen properly, but it prints dark black and is very distracting from the rest of the elevation.  I have tried printing in both grayscale and black/white with no luck.  Is there something else I can do?
Wed, Jul 13, 2011 at 4:20:45 PM | Material hatch will not print gray, only black
jnpowell
Sorry.  I am in 2011.
Thu, Jul 14, 2011 at 8:16:53 AM | Material hatch will not print gray, only black
If your model material hatch is printed at small scales, you will have problems because of density.  The color you picked has nothing to do with the hatch, that is for shaded views.
You might try over-riding by element in these views but if you have very many instances, that will be a problem.  You might look at just a slid fill hatch, grey - instead of your lined hatch.
Gray Hatch Lines
Mon, Sep 2, 2013 at 8:01:02 PM
Existing Walls Printing Black (SHOULD BE GRAY)
Tue, Mar 27, 2007 at 12:42:28 PM
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:40 AM
PRINTING COLOR HATCH TO BLACK
Tue, Aug 16, 2011 at 1:59:52 PM
Print color lines in Black
Fri, Aug 8, 2008 at 11:15:34 AM
Page generation time: 1.3246
