37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> on/off parameter depending on other on/off parameter
Wed, Jul 13, 2011 at 9:51:58 AM | on/off parameter depending on other on/off parameter
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I am trying to get this family to work properly.  I have a cubilce with 2 walls and 1 corner connector.  Both walls are controlled with on/off parameters: "Wall 1 on_off" & "Wall 2 on_off".  I have another parameter: "Corner Connector on_off" that I want to enter a formula that if Wall 1 or Wall 2 is off, then the Corner connector is off.  Basically the Corner Connector is only one when both Walls are on.
I have tried this: not(Wall 1 on_off)  but that basically turns the corner connector on when Wall 1 is off.  Which is not what I want.
Make sense?
Thanks in advance,
Lorne
Denver, CO
Revit Architecture
Wed, Jul 13, 2011 at 10:16:44 AM | on/off parameter depending on other on/off parameter
TKennedy
4 Stars: 8 Votes
Try 'and(Wall 1 on_off, Wall 2 on_off)'
Wed, Jul 13, 2011 at 11:58:58 AM | on/off parameter depending on other on/off parameter
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Worked like a charm.  I knew it was simple.  Thanks,
Lorne
Denver, CO
Revit Architecture
NOT Parameter Formula Question
Fri, Apr 10, 2009 at 8:30:17 AM
Using instance parameter in type parameter formulae
Mon, Aug 12, 2013 at 8:22:38 AM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
If/Then & Yes/No Parameter Condition
Fri, Aug 29, 2014 at 2:18:54 PM
Page generation time: 0.1810
