28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Cutting an Elevation Crop to Have Different Depths @ In Two Places
I have an elevation that I need to "break" the view plane of. If you look at the files attached, in plan, I want to see the exterior (south/ down) elevation of the wing with the red bubble around it. Though, if you look to the west (left) you can see a deadend alley of sorts that I need to see the extents of in elevation, as is shown in the elevation, which is also attached. The elevation view plane in question is also highlighted.
Thanks,
.blc
You can't have an elevation with a split depth.
A work-around: You can have two elevations side by side and placed side by side on your sheet. Use one title to represent both.
Thanks for your response.
Perhaps for 2012?
.blc
Elevation bugs show up out side of Crop Region on sheets.. Why? |
Wed, Sep 6, 2006 at 7:38:06 PM
Backwards Crop Box on Interior Elevation |
Mon, Sep 24, 2012 at 2:02:32 PM
elevation crop boundaries |
Fri, Jun 6, 2008 at 5:08:18 PM
Interior Elevation - Crop Region - "lineweights" |
Tue, May 8, 2007 at 10:25:02 AM
My section crop regions are misbehaving |
Thu, Nov 30, 2006 at 2:49:24 PM
