Forums >> Revit Structure >> Technical Support >> Invisible text
Wed, Jul 13, 2011 at 5:33:34 AM | Invisible text
marienvanee
Is it possible te create text which is only visible on screen and not visible on printed sheets ?
Wed, Jul 13, 2011 at 6:36:59 AM | Invisible text
No.
I suggest you use working views for in house notes.
Thu, Jul 14, 2011 at 10:37:07 AM | Invisible text
emgeeo
3.5 Stars: 7 Votes
agreed.
also, we use text styles devoted specifically to internal comments.
two reasons we do this:
1.  visual distinction between documentation and internal comments
2.  thoroughness - we are able to select all instances of the text type to ensure we haven't missed anything, and to make sure none of these comments end-up in a deliverable set.
Edited on: Thu, Jul 14, 2011 at 10:37:34 AM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:48 PM
cant copy text between elevations
Fri, Apr 27, 2007 at 6:52:11 AM
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:49 PM
Page generation time: 0.4188
