26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> Structural Column Family file
2 Posts No Rating |
I am new to the Revit community and am currently teaching myself Revit. I was informed that my software should come with the structural columns family already installed, but I can not find it anywhere. Could someone send me this family file?
2 Posts No Rating |
I have Revit 2011.
You should find most of this information in the metric/imperial libraries which come with the software.
if you go to the following ribbon location:
Insert -> Load Family
you will find a dialogue box with icon-links on the left-side. The libraries should appear here. If not, go to:
Revit icon fly-out/drop-down (upper-left corner of program window) -> Options (next to exit revit on lower-right-hand-corner of fly-out) -> File Locations tab -> Places...
There is where your library is mapped to. This is where you will find the pre-loaded content. Structural columns are under structural columns, if memory serves me correct. There may be a structural folder. not sure- i am using a german version of revit.
If you do not have a library for some reason, then you should say so- someone, not me, can help you install the library. i know they are available for download from somewhere (subscription may be required.)
Otherwise, you can always download content from seek.autodesk.com
Make sense?
structural column family |
Tue, Oct 25, 2005 at 9:29:56 AM
structural column member not selectable |
Wed, Jul 19, 2006 at 9:26:06 AM
Visibility graphics of a structural column |
Mon, Aug 16, 2010 at 8:21:00 AM
Constraining Structural Column Within a Revit Family |
Fri, May 9, 2008 at 3:22:04 AM
Best Practices - Coordinating Column Grids Across Arch. and Structural Models |
Wed, Nov 11, 2009 at 9:32:25 AM
