Forums >> Revit Structure >> Technical Support >> Reference DWG disappearing when zoomed
Mon, Jul 11, 2011 at 8:35:28 PM | Reference DWG disappearing when zoomed
rgvjr
Anyone has an idea why in some cases an inserted dwg (in a section) (version 2011/2012) disappears when zoomed in.  The dwg file has been cleaned/sorted but still cause the same problem.  When a similar file (generared from the same dwg) is inserted in another location it behaves as expected.
What is causing this problem?  Thanks.
Mon, Jan 2, 2012 at 2:28:43 PM | Reference DWG disappearing when zoomed
e00878
is your dwg file content located far away from 0,0,0 point? if yes, it may be issue. please check this in autocad not revit.
http://www.revitwatch.com
Linked CAD background disappearing....
Mon, Feb 25, 2013 at 4:49:03 AM
14
Disappearing Callout Reference
Tue, Feb 24, 2015 at 8:09:23 AM
Sketch Mode: reference linked dwg lines disappear
Wed, Oct 17, 2012 at 9:59:19 AM
imported images black when zoomed in
Fri, Sep 26, 2014 at 9:01:52 AM
Section References Disappearing
Sun, Sep 13, 2009 at 11:40:02 AM
Page generation time: 0.2092
