26 Users Online (24 Members):
Forums >> Community >> Newbies >> Architecture RFA to MEP?
20 Posts No Rating |
Is it possible to convert an architectural family into a MEP family? I have a light that I want to use, but am unable to because it has to be placed onto an actual ceiling as opposed to a linked ceiling.
Thanks,
Jack
8 Posts No Rating |
If it requires a ceiling I'd make a small and thin ceiling that can be hidden between your linked ceiling and the light itself. Not sure if it is like Revit Arch 2010 where you can export to AutoCAD then Import from CAD.
Your question is a little confusing. You can create a new MEP family ceiling based and insert the architectural family into it. Thus allowing electrical connections loads and light source options. Regarding the linked ceilings, go ahead and make the ceilings in the MEP model.
I just wanted to check if there was a way to do this without making a ceiling within my model. It doesn't look like there is, but thanks for your input.
Is there anything Revit Architecture can do that MEP can't? |
Fri, Apr 17, 2009 at 5:10:43 PM
MEP and Architecture Intigration |
Fri, Sep 25, 2009 at 2:22:32 PM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP |
Thu, Aug 26, 2010 at 7:48:24 AM
MEP in Architecture |
Tue, Dec 6, 2011 at 12:05:17 PM
Linking Revit MEP, Structural Models into Revit Architecture |
Mon, Apr 23, 2012 at 4:00:03 PM
