Forums >> Revit Building >> Technical Support >> Levels list order
Sun, Jul 10, 2011 at 11:16:59 PM | Levels list order
fabioloretti
3 Stars: 2 Votes
Hi guys, would you know the logic behind how revit orders the levels list when I'm changing the constraints of a wall for example?
Clarifying my question, I've got a file with 7 detached houses, each of them with basement, ceiling basement, lower ground, upper grd, ceiling lower grd, ceiling upper grd, lower first, upper first, ceiling lower first, ceiling upper first and top ridge levels for each unit. That means I have a long list to browse through when I need to change a wall top or bottom constraint for example.
The bad part is that the list apparently doesn't follow any logic in the way it is sorted, or is it?
Is there a way to reorder that list so I don't waste so much time looking for the level I'm after?
Any help is appreciated.
Mon, Jul 11, 2011 at 7:28:40 AM | Levels list order
You will find that these houses would have been done easier in seperate linked files.
Any way to change the order of Revit Design Options in the list?
Tue, Nov 1, 2016 at 12:33:21 PM
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
Component List Order
Wed, Sep 28, 2011 at 10:18:31 AM
Drawing list sheets are in incorrect order
Fri, Jul 9, 2010 at 10:59:05 AM
sheet view order
Fri, Jul 24, 2015 at 10:28:05 AM
Page generation time: 3.8380
