Forums >> Revit Building >> Technical Support >> hatch editing Rev 2009
Fri, Jul 8, 2011 at 9:58:56 AM | hatch editing Rev 2009
tmassey
tmassey Avatar
stay with me on this one. sorry if my editorial is confusing.
110,000 sq ft commercial project many sections call outs and drafting views. Workshare file
Would the Section detail with filled region diagonal hatch be affected if you change the scale of the same hatch in a drafting view?
Section detail 1/4"
drafting view edit the hatch to 1/8".
drafting view is not a callout it is a dwg. I know I know but we are running out of time and this is our first full Rev project
make sense?
Using Revit Architecture 2012
Fri, Jul 8, 2011 at 10:20:54 AM | hatch editing Rev 2009
Here are the rules and they are simple:
Model patterns are like the model - they scale with the view.
Drafting patterns are just like text and other annotative elements.  They will always PRINT the same no matter the scale of the view.  If you have a diagonal hatch that prints at 1/8" spacing - it will print that way in every view - has nothing to do with the view scale.
Fri, Jul 8, 2011 at 10:24:53 AM | hatch editing Rev 2009
tmassey
tmassey Avatar
Understood but not what I was asking. If I edit the scale of a hatch in a view it will revise the hatch throughout the entire project.
Change a diagonal hatch in the editor from 1/8" to 1/4" in a drafting view...changes the hatch size where applied in all views.
Fri, Jul 8, 2011 at 10:57:16 AM | hatch editing Rev 2009
I did answer you!
The drafting pattern will print the same in every view.  The only way to edit the "scale" of a custom drafting pattern is to reload at a different scale.  Is that what you did?  Or is it a simple pattern that you changed the spacings under the manage tab?
Withe either of these, the change is project wide.  If you want a different spacing in one instance, you need a different pattern.
Fri, Jul 8, 2011 at 11:23:09 AM | hatch editing Rev 2009
tmassey
tmassey Avatar
Thank you. it was the spacing within the editor I changed and it did i project wide.
have a good weekend
REV 2009 titleblock arch stamp
Thu, Jun 30, 2011 at 3:39:35 PM
3d dimensions Rev 2009
Wed, Jun 22, 2011 at 12:40:13 PM
RAC 2010 - Revision Block Disappears on Rev. 2
Thu, Jul 8, 2010 at 11:16:36 AM
Rev 2009 Importing Structural Dwgs into Arch dwg
Mon, Jul 25, 2011 at 7:39:15 AM
Rev 2009 Journal Files
Thu, Sep 1, 2011 at 9:04:39 AM
Page generation time: 3.7603
