Forums >> Revit Structure >> Technical Support >> Plug-ins?
Wed, Jul 6, 2011 at 8:07:43 PM | Plug-ins?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I've just had my first brush with plug-ins -- using Hatch-22 by mertens3d, and I'm very impressed!  instead of fighting with old ACAD pats and converting them to be model, and struggling with scale... I can draw the exact hatch I want, tell it if it's drafting or model, and BAM. Copy/paste perfection into the project.  I've now set up a project file on our network that's just a laboratory and library for new patterns.  (they reccomend you don't use the plug-in outside of test projects, it's beta)
So I'm wondering if there are any other good suggestions you guys might have, for plug-ins that you've found are real time-savers and a worthwhile addition to the basic Revit software.  Testimonials would be great.
Edited on: Wed, Jul 6, 2011 at 8:09:21 PM
Thu, Jul 7, 2011 at 6:52:00 AM | Plug-ins?
Be careful with these.  If you have to export to CAD, some of the hatches made from the Revit plugin don't transfer.
Thu, Jul 7, 2011 at 9:25:19 AM | Plug-ins?
pchan
pchan Avatar
5 Stars: 5 Votes
Here is a list of plug-ins for Revit. I believe many of them are free (which I tried it in the past) and some are paid version that has trial period.
http://whatrevitwants.blogspot.com/2011/07/free-revit-add-ins-get-your-free-revit.html
HTH
Wed, Aug 24, 2011 at 9:10:21 AM | Plug-ins?
viper11
Where on your drive did you place the Hatch-22 file. He says to place in the 'add ins' folder but there is no such folder. Is the plug in folder the same thing.
A little help...thanks
Wed, Aug 24, 2011 at 9:28:05 AM | Plug-ins?
pchan
pchan Avatar
5 Stars: 5 Votes
You need to create a folder on your own under your local "C" drive.
I don't remember exactly how I did it before. you can post your question if needed more help
Wed, Aug 24, 2011 at 10:20:05 AM | Plug-ins?
TKennedy
4 Stars: 8 Votes
Xrev Transmit has been a huge help in my office.
Fri, Sep 16, 2011 at 10:11:19 AM | Plug-ins?
mertens3d
5 Stars: 2 Votes
Viper11,
Were you able to get hatch22 installed and running?
If not, take a look here for the correct location:
http://mertens3d.com/tools/revit/2012/hatch22-2012/hatch22-2012-download-install.php
...gregory
my Revit - Bugs/ Issues/ Requests
Fri, Sep 16, 2011 at 10:20:21 AM | Plug-ins?
viper11
no mertens, i have not been able to. I have read over your post, but still hava a question as to where to place the download in order for it to load. For 2011 - I have a 'plug-in' folder but not an add in folder. Are they the same or do you need to create this folder?
thanks
Fri, Sep 16, 2011 at 10:31:47 AM | Plug-ins?
mertens3d
5 Stars: 2 Votes
Viper11,
1) What is the full path of this plug-in folder?
2) Can you browse to this folder? Put the full path in the address bar. It might be that your system is hiding these files by default. Let me know if so.
  1. For Windows XP - C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2011\
  2. For Vista/Windows 7 - C:\ProgramData\Autodesk\Revit\Addins\2011\
3) To answer your question, plug-in and addins are not the same folder. I'm not sure where plugin is coming from
4) the addins folder should be created for you by Revit. You should not have to create it yourself.
...gregory
Fri, Sep 16, 2011 at 10:39:47 AM | Plug-ins?
viper11
thanks...found it. Things were hidden.
Fri, Sep 16, 2011 at 10:54:12 AM | Plug-ins?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
with the help of a database designer I have created a nice door plug in that will automatically label all doors in the project to the room they are associated to, it also gives you options of cycling through doors one at a time and pick the to or from room and add an alphabetical suffix
Edited on: Fri, Sep 16, 2011 at 10:54:30 AM
Fri, May 8, 2015 at 3:09:43 AM | Plug-ins?
hugh
3.5 Stars: 4 Votes
Our HatchKit Add-In for Revit 2016 is now available from Autodesk's Revit Exchange:
https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3ahatchkitforrevit2016_windows64%3aen
HatchKit itself is not tied to any particular version of Revit, instead we issue a free connector as an add-in for each new version of Revit as it is released.
Hugh Adamson
www.hatchkit.com.au
Fri, May 8, 2015 at 5:35:33 AM | Plug-ins?
#13
abhi3v2
Hello revit experts... Winking Can anybody tell me how to re attach a local file to central.  Actually accidentally i'd detach it from the central. Sad
Fri, May 8, 2015 at 8:03:35 AM | Plug-ins?
#14
Wrong place for this post abhi ....
You can not attach a file to a central but
  • if nobody else is working in the project and if you preserved worksets, you could create a new central from the file you are in.
  • If you removed the worksets, you could re-enable worksets and also make a new central but all workset assignments would have been lost.
  • If both of the above will not work for you and you have work you need to preserve, while in the same Revit session, you can properly create a new local from your central and copy/paste between your bad file and your new local.
Revit Plug-Ins
Sun, Dec 30, 2007 at 3:25:04 PM
Add-ins, Add-ons, Plug-ins
Wed, Aug 31, 2016 at 2:20:36 AM
Green Building and Revit
Thu, Nov 3, 2005 at 6:37:58 AM
Revit Architecture 2015 Add-ins
Tue, Aug 26, 2014 at 9:06:19 AM
Free Revit Plug-ins for Implementing BIM on Federal Projects
Thu, Jun 23, 2011 at 7:07:17 AM
Page generation time: 0.0353
