14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> stair baluster rotation?
11 Posts No Rating |
Does anyone know how to get railing balusters to work like the railing in this Kundig building--that is, how to angle them 90 degrees to the angle of the stair run? This is as close an image as I can find online. Thanks.
The railing tool will not work for specialty railings like this. Use the railing tool to make the railing only. Then add ballusters seperately from a family you create.
Thanks WWHUB. Do you mean that the balusters--in this case both the posts and the verticals for the wire mesh--would need to be inserted separately  same as a mass) and rotated in space without association to the railing? I think you're saying that the rail structure will handle it, because the rails run parallel to the run, but not the balusters? Thanks for the clarification.
Railings in Revit can be a challage but some people are up to it: http://revit-alize.blogspot.com/2005/11/stairway-to-heaven.html
2015 use baluster per tread on stair (with no top rail?) |
Thu, Sep 3, 2015 at 4:50:57 PM
Baluster per tread on curved stair |
Thu, Apr 4, 2013 at 2:18:52 PM
Spiral Stair Baluster Problem |
Fri, Feb 26, 2010 at 3:53:38 PM
stair railings-inserting glass |
Mon, Dec 9, 2013 at 11:37:40 AM
STAIR BALUSTER OVERLAPS?!!! |
Mon, Mar 26, 2007 at 4:26:54 PM
