Forums >> Revit Building >> Technical Support >> Cavity walls
Tue, Jul 5, 2011 at 2:48:07 AM | Cavity walls
gastonverdicchio
Hi There,
I have a cavity wall and as such I would like to visualize inner+cavity+outer leaf of wall instead a solid element. the scale of dwg would be 1:50 so it deserves I think to be seen how the wall is made of
Gaston
Tue, Jul 5, 2011 at 6:56:30 AM | Cavity walls
If you want it to show at that scale, you wall have to create it as two walls with a cavity between.
Tue, Jul 5, 2011 at 7:07:42 AM | Cavity walls
gastonverdicchio
So the cavity will appear as such at a scale like 1:20 on wards?
Many thanks WWHub
G.
Joining different Cavity walls
Mon, Jan 5, 2015 at 12:26:43 PM
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:38 AM
Cavity Wall Around Bay Not Showing Correct Detail
Sun, Jan 17, 2010 at 3:50:13 PM
Cavity wall for Revit 2008
Thu, May 26, 2011 at 12:06:42 PM
Sales plan - Black in where cavity closers have been
Wed, Apr 14, 2010 at 6:39:10 AM
Page generation time: 0.2987
